I like misting RAW gas from a sprayer bottle. to make it run...
Good postings above... I'll try to help....
If it does pick up in speed spraying raw gas into the venture,,, you know it is in the carb.
If there is enough fuel in the carb to get the bike warm, then Not enough to keep it running at any speed and dies no or low fuel is probably the cause.
The suction (vacuum ) hose to the carb from the gas tank shut-off valve.
leave Carb on bike,,,,,, air cover and cleaner off......Take the carb bowl off and let the float drop on it's own, hanging.
By mouth, apply suction on the Vacuum line (off carb) that opens the gas tank valve and let raw fuel come out...
With the float in the totally dropped position and using a clean catch can , allow gas to run out the tank thru the float needle. This should allow most debris to clean out of the line... (float needle valve will allow MOST small Junk to go past in this position)
Taking off the float IF it didn't improve the flow.... Flow should be a good stream FLOW with what is being done above.
Looking into the can for dark matter:newsmile073: IF a lot of black pieces and the FLOW Improved and is GOOD,,,,, I have buttoned a bike back up to save labor and running was fine...
IF there is NOT a good Piddle flow
(keep the suction on the valve,,,,apply tongue and see IF the Flow is still there and NOT leaking off)... Vacuum not loosing ? continue as below.....
If Not a good flow from the tank to carb. The tank to carb line can be the problem with debris in the tank valve screen or tubes..
IF not much flow into the can Move the tank valve to Reserve and see IF that improves.. IF not you see where the fuel com'n in is the problem. (tank to carb)
You get the Idea here...
Don't forget to put the excel. pump arm back into the proper place.... and use the rubber protector...
