Yes it is!It's Gone!
Yes it is gone now but what are you doing about a possible virus on the forum?Could be some kind of virus if it just started. Might try to run Malware bytes.
We all have this forum in common and between us we have used several browsers (I have used Chrome and Firefox) and we all saw a pop up that no staff member is giving an explanation for on this forum. Since you or others in positions of authority have not said the pop up was intended then we have to assume it was a virus that is on this website. What is being done about that?
Some better info from those in charge would be helpful. If it was intended then say so. If it was not then you should warn us officially that the forum has an issue.
As I said above, I tried both Chrome and Firefox and saw the ad blocker pop up with both brands of browsers. I don't believe you can say it is a Firefox only issue. With this many reports and different browsers being used, I think this website is the source. This forum and the use of ad blocker is the one common thing that all those that who have seen it have in common.Not sure if anything was done. It appears to have been an issue with firefox, not IE or Chrome. I did not see it on FF when I logged in with it this morning on my PC at work. But, I run Malware Bytes about once a month anyway.
I run virus software and Malwarebytes as well. I also use ad blocker and saw a warning that said I should turn it off. With every click I made on this website it re-issued the ad blocker pop up. If as you say, "nothing was done" and "there was no sanctioned action done" by those of you that run this forum then you must have a problem with the website that triggers a warning to those of us using ad blockers. Just trying to help you understand.
