Thanks Guys for the info.
GS34
I will call the Service Tech tomorrow and check out the Service Bulletin # 903 issue. I'll post what I find out.
Blues Fan
I checked the ignition switch connections as I thought this might be a problem also Unless it's loose inside it seamed good to go. Thanks for the info. You never know.
Horizon Chaser
That worked on the older bikes and was a Service Bulletin
Anyways, I had a guy contact me via email and suggested that the Main Breaker was getting to hot and he had the same problems. He found his breaker about 1 inch away from the rear exhaust. He moved the breaker and has never had the problem since?? I also checked the breaker on my bike and it was about 1 1/2 inches away from the rear exhaust also. So I moved it up under the seat about 6 inches away. As I told him stranger things have happened and I knew everyone has had that Your not going to believe this moment. I will check the other suggestions out and get back to you all. Thanks Again for all the help. Thanks Charlie, You know who you are..
Foxtail
