stuck oil filter help
Discussion in 'Touring Models' started by djdmad, Nov 14, 2009.
  1. djdmad
    djdmad New Member
    3
    Had a weak moment and let dealer do my 20k service oil change . Started doing my 25k oil change and when i tried to remove the oil filter with the hd filter wrench it just slipped and would'nt loosen the filter. I then tried my web strap oil filter tool and the filter just bent and still would'nt loosen. Anyone had this problem and if so how did you get it loose . Not much room to get to the filter . Would penatrating oil help ?
  2. STEVE07
    4,122
    68
    82
    I had that problem a while ago.I ended up driving a screwdriver through the side of the filter and using that to loosen it enough to turn off.Messy,but it worked.After I was done I pressure washed the area below the filter making sure I got the oil out of the motor mount area.
  3. Dr. Dolittle
    6,404
    118
    29
    What Steve forgot to say was that he CAREFULLY drove a screwdriver through the filter! You don't want it coming out the other side and causing damage to other stuff.
  4. cool breeze
    cool breeze Active Member
    147
    don't know how bad it's bent but i had this problem if you can find one they make a piece of thin rubber for looseing jar lids put it between the filter & filter wrench its tight but it will work
  5. 1fltri4me
    1fltri4me Member
    68
    I had to use some large Channelock pliers.
  6. hoggy25
    hoggy25 Active Member
    127
    I've had the same problem in the past on other bikes. I used and old belt, looped it around what was left of the filter, than back through the buckle. Pulled end of belt with a steady pressure until it loosened. If you have a big enough pair channelock pliers as mentioned above that would work too if you have the room. Not eneough room on my UC for channelocks I don't think.
  7. AcidRayn
    AcidRayn Active Member
    126
    gotta be careful with the screwdriver, you might tear the filter apart,
    and the base still be stuck. i worked in an oil change place for a bit,
    seemed like when i would get a stuck one, the rubber gasket would be
    fused to the plate from no oil being used on the gasket on install.
    tried the screwdriver and channel locks, sometimes they work, but if they
    dont, you can make more work for yourself.
    go to pep boys or whatever you have around your, sears is best and they have it,
    its an oil filter wrench, the strap type, but it uses a 3/8 ratchet, it has no
    handle, get it as close to the base of the filter, the closer the better, this is
    the strongest point of the filter. good luck
  8. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    My filter wrench is a tiny bit bigger than a HD filter, and I always do like "coolbreeze" suggested above. I put a socket extention on and tap the wrench onto the filter. When all is in place, I try and give it a "quick" twist to break it loose. I have resorted to the screwdriver thru filter method more than once.
  9. cavs1429
    cavs1429 Member
    85
    8
    :worthyOk after a Gorilla tightens your oil filter so tight that nothing seems to work this is what i use and it never feels me. snap on tools sells a strap wrench that takes either a 1/2 or 3/8 drive rachet put strap wrench on the filter with an extension and hold pressure on it until it loosing up it will work. And of course counter clock wise
  10. fin_676
    5,775
    153
    284
    Over the years of removing oil filters ive been through many different types started with the big srewdriver driven carefully all the way through the filter then strap wrenches and chain wrenches im currently using a sort of tripod that fits over the end of the filter that will take 1/2" or 3/8" square drive and grips tighter the more pressure you put on it and usually puts three deep dents in the filter where it grips great tool
    foung it in halfords profesional range of tools
