+! on using a good oil in the transmisison like Royal Purple, Spectro (my choice) etc... I have noted the significant reduction in metal on the magnetic plug. In the last 3 transmision changes I have had NONE on the plug. When I got the bike (used) I switched to HD Syn3 until I got educated at HDT. By that time I had 4k from the original owner (probably never changed the oil) and 15k with Syn3 in all the holes. I followed a 3k change routine. I have been with full synthetic in all holes since 19K and now have 37k on the odometer. From the data with the synthetic oils and what my eyes tell me in looking at the old fluids vs the new ones: synthetic is better in just about everyway except price...but you get what you pay for.
Am I doomed to an early transmision grave becuse of syn 3 for 19K? Who knows. Maybe I had a poorly manufactured transmission and it will blow up at 42K no matter what oil I use. Maybe my riding style (lots of flat highway) and better synthetic fluids will save me. Maybe not. Be reasonable and by all means go riding instead of worrying. I may not be able to afford a new tranny if it is not under warranty, but I will be able to say I road it till it blew up!
Speaking on belts and bearing wear:
I don't know if the suggested spec is too tight or not, but I agree that there is such a thing as "too tight". Now, I am no engineere, but we use toothed belts like this to drive a 2 story tall centrifuge. The belts have metal wire in them to keep them from stretching under load. I think the drive belts probably have metal wire in them as well, but I don't know for sure. We have to keep high tension on the centrifuge belts because when loads change there is an increase in tension on one side of the belt due to the teeth (like a chain on your bike, only the top of the chain has tension when you stomp on the pedals). V-belts can slide a bit in the groove and even this load out a bit. What we found is that if the belt is too loose, you can have a tooth skip a little from the stretch that occurs. Even thought there is metal wire, it still stretches a little. This wears the loaded edge of the sprocket tooth, which then adds more slop to the whole system and then there is a cyclical worsening of the whole situation.
So, to me if you ride and shift easy (I don't know how to define one rider vs. another) you should be able to technically increase the life of your bearings by reducing the tension load on them and if you shift easy and are easy on the throttle, it shouldn't really matter. But, that's alot to ask, since I love to wind it up a bit every once in a while.
Again, this is just my thinking. I don't really see transmissions or bearings blowing up all over the road or internet. While I would love for my UC to last for ever, I also want to have some fun and enjoy it.
To me there are usually too many variables to know true cause and effect for most failures. The fact that most riders say they ride "normal" is a big variable. Only a few say the ride hard.
Can't remember if it was Bubbie or Hoople that said to basically listen and watch and see what happen as more long term data and experince comes in. I think that is good advice.
And as usual, (I think) Smitty hit the nail on the head!
