My shift lever was getting so loose that I couldn't shift from neutral to 1st anymore - had to go to 2nd and then back to 1st. Only a matter of time before I was going to get stuck on the road. And I'd just had the primary off a couple months back to replace a drive pulley (went with the Baker) at a local shop and they'd been unable to tighten the shift lever because they said the shifter shaft splines were worn.
Ordered a "Better Lever" last week, picked it up yesterday, installed it last night. Had watched the videos posted on the betterlever.com website and it was a pretty straightforward 2 hr job done sitting on a milk crate in my garage. Most of the time waiting for my little hobby Dremel tool to chew through the old lever.
My Dremel tool came with the flexible cable attachment (always wondered if I'd ever use it), I attached a little cutoff wheel - you can't go too big, Conrad recommends about a 7/8" wheel. Cut off the lever first, realized I had cut if off too high and then cut it off again closer to the bottom. Then I used a pair of needlenose pliers to hold the remaining lever collar to one side or the other while I made the crossways cut so it would fall off the shaft. Pried the cut with a large screwdriver - as shown in the video. Top half broke off and then a tap on the bottom and it fell off too. No need for a magnet, everything just falls to the floor on my FLHS. From there just bolted the new one on with blue loctite on the threads. 3/16" hex bit with an extension and wobble on a 1/4" drive ratchet. The 3/16" Allen socket on my 3/8 drive wouldn't fit in the close quarters of the lever. Easy. The lever is tight now. A day's riding today and still tight. Now there are two bolts (front and back) in the grove on the shaft to hold it in place. Did I say tight yet? As in does not move on the shaft at all.
Oh, and I mentioned HD Talking on the order, but no discount or free shipping, so I guess that intro deal is over. And the videos are no longer posted on his website for some reason. Maybe he didn't black out a HD logo on the bike he was working on.
I'm happy with the kit. Saves pulling the primary, and if the shifter shaft is worn it saves you pulling the tranny apart to change it. And for all you guys torquing on a 5/16 x24 thread 1" bolt with a 1/2 drive wrench and cheater bar to get the old lever tight, just think what you are doing to the shaft bushing and seal. No thanks.
karmutzen
