I have had a need in the past on a few bikes for a replacement part such as this and they were not available so I am posting this to help out the members that may run into this problem.
Here's a nice way to save a lot of work if the spline on the shift lever strips out which happens more than it should. Rather than pulling the inner primary off to replace it, this unit can be installed without all the work previously needed to replace the lever. It's made from Stainless steel and the nice part about this lever is that even if the shift shaft is stripped out from the loose factory shifter arm, this unit will grip the shaft making the replacement of the shift shaft unnecessary.
