joel
Well-Known Member
After a few different tries, this works to collect oil from oil filter when servicing your bike, using a 1 gal. washer fluid bottle, cut to size as shown in the picture, install in front of filter and past the filter housing, rotate counter clockwise, this will collect the oil as you spin the filter loose, pull filter away, place a rag in your oil collector to absorb oil, remove collector and install new filter and tighten as required. This will help protect the front engine mount and voltage regulator from oil
