Air Pressure in Tires
Discussion in 'General Harley Davidson Topic' started by franka, Sep 13, 2010.
  1. franka
    franka Active Member
    315
    8
    May sound like a very silly question but does it matter if you check your air pressure with wheels on the ground or off the ground? Certainly much easier to check when I can freely spin both front and rear while off the ground on my jack.
  2. doc_63
    doc_63 Active Member
    319
    Either way...doesn't matter
  3. Jack Klarich
    Check them cold with a good gauge:s
  4. Hoople
    Hoople Account Removed
    7,198
    34
    You really mean it's not enough to worry about,, correct?
  5. nakkers
    nakkers Junior Member
    412
    13
    The weight of the bike (or lack thereof) won't affect the pressure. As Jack says, check and adjust when cold.
  6. Hoople
    7,198
    34
    Of course it does. The more weight the tire is supporting, the higher the pressure will be.
    I am talking in absolutes terms and not something that needs to be corrected for. Do you mean the same?
  7. sprinklerfitter669
    sprinklerfitter669 Junior Member
    982
    6
    I would think that bike needs to be on the ground.
    The tire IMO is just like a Balloon, the more pressure you put on it, builds up the inside pressure ......untill POOF !
  8. Jack Klarich
    POOF ALL GONE, hmmm I remember that it was Glider:s
  9. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Agree w/Jack - bike grounded, cold & use decent gage. I ended up getting HD's dial gage to fit into the tight space under back tire/swingarm/bags.
  10. Jack Klarich
    Got a Snap on just like it with jewelled innards works good very reliable:s
