Road test 2 complete.
Before I left, the following was done.
Pushed in on both spark plug wires (back side) on coil===Loosened, sanded, and re-attached the 2 wires on the front of the coil, and the 2 (2 wires connected with 1 single terminal) wires on the back of coil===Took ground screw completely out of ingnition module along with 2 wires, sanded both sides of each wire, and also what I could on the metal bar type piece attached (ground) to the frame===Left in the same plugs from before in particular the 1 in the rear cylinder which was slightly dark w/a hint of gas smell===and after last ride as I mentioned I found the frayed "outer" coating wire that went from the ign mod to the nose cone to which I inspected the best I could, found nothing, so I left it as is but made sure it wasn't against the metal piece that wore down the sleeve.
Drove about 14 mi this time & very quick had 2 short hesitations within a split second but NO backfire, and NO stall. Continued to drive hoping it would fail. Had it up to 75-80, down to 35 or so but on average, 55 the whole way. Sat on the side of the road @ idle, stopped and got gas shutting it off, and after 70 mi, I finally gave up. Not 1 backfire or anything. When I got home while it was running, I unsrcewed both the front and back screws of the coil but it would not stall. As soon as I started to unscrew the ign mod screw, it sputtered then stalled. So here are my questions.
1) Should I strip the casing off the wire from the ign mod as much as I can and tape back w/ electrical tape? I'd replace it but that would mean the whole nose cone wiring.
2) Should I replace both spark plug wires just to be on the safe side?
3) Could that one single ground screw be the likely cause of all this?
4) Could 1 of the 2 coil wires been loose on the back side just enough to cause all this?
Shirley agreed she would take a ride tomorrow for lunch. The trip is about 20 mi one way. I intend to replace both spark plugs with a fresh set, remove the ground to the ign mod once again & this time, clear a larger base area for that screw to ground, remove the coil so I can see the back & make proof positive they are in tight.
Thanks in advance to all. Can't tell you how much I have learned and also appreciate all the help thus far.
Paul
Paul
