Zenith/Bendix 13859 carb
Discussion in 'Classic Models' started by 62pan62, Apr 21, 2009.
  1. 62pan62
    62pan62 New Member
    3
    I need to rebuild a Zenith 13859 carb. it has a adjustable main jet I could use a breakdown pic. and any advise and info...
    Thank you
    What's it on?
  3. 62pan62
    62pan62 New Member
    3
    Its going on a 62 pan
  4. R. Lewis
    2,183
    5
    Have you checked out "thecarburetorshop.com site?
  5. 62pan62
    62pan62 New Member
    3
    Yes I have, but no breakdown down pic., I have no trouble getting the rebuild kit its the pic. that would be so help full.
  6. STEVE07
    4,124
    68
    84
  7. Caper
    Caper Active Member
    236
  8. The Don
    The Don Member
    13
    Hi ,
    This may help,
    I ran a modified Bendix on my 81FXEF, removed choke assembly and plugged and smoothed the mounting holes, polished the throat, drilled and polished all sharp corners in the fuel intake. Matched the intake manifold to it and had the adjustable mainjet fitted. Ran the mainjet 4 turns out and the low speed needle 1 1/4 turns out. Bike was stock 80cubes running forged manley pistons w/ 8.5 to 1 comp, manley valves, seals and guides. Used to eat Evo's for breakfast.
    [​IMG]
  9. RonW
    RonW New Member
    I don't know what happened to 62Pan62 who raised the original question, but I just registered on this site so that I could tell The Don:
    You Rock!!! Thank you thank you thank you! :D
    Picture is extremely helpful! So are the needle adjustments. I assume my Bendix is not modified and I wasn't planning on modding it. Do those settings for main jet and low speed needle still apply, or would you suggest something different to start after I rebuild this puppy?
  10. The Don
    The Don Member
    13
    Hi RonW
    If you are running your carb on a Sportie I'd stay at 1 1/4 turns out for the low speed needle and start at 4 turns for the adjustable mainjet and work from there by reading the plugs.
    Regards, Cris aka The Don.
