Windshield Problem
Discussion in 'Touring Models' started by Fourdogs, Oct 3, 2007.
  1. Fourdogs
    Fourdogs Junior Member
    805
    3
    Windshield question...I tryed cleaning ..or buffin out some fine scratchs with a product (thats what its suppose to do)..now it seems smeared. Not sure I am allowed to say the products name...but is there anyway I can get out all the smudges and bring it back to life. Its ok in the daytime..but looks like crap at night.:wall
  2. Speed
    Speed Site Tech Administrator
    2,945
    Fourdogs,just mentioned the products name here because you are seeking the answer.It will be easier for us to answer your question.
  3. Fourdogs
    805
    3
    Hey Gentleman..Thanks for a quick reply..The name of the product is Novus 2 fine scratch remover..did not come close to doing what iit says ..unless I'm doing something wrong. I am using cotton/Flannel cloth (new)..thought I followed directions as stated on product directions....when I can post a pic of my bike ...I can show you why its important to me....Thanks again
  4. glider
    56
    The novus products come in different numbers, the 2 is more abrasive than the others in the product line which get finer with numbers down to a cleaner. Usually you use them in order to get the shine back where it should be. You may try a bit of liquid car polish on a spot and see if it does the job, but one without any abrasives in it. Generally there is a hard coating on the winshields at least on the front side and if you go through that it will leave a ring where the edge of the coating will be obvious. Work a small area to test where the results are going before getting into the entire screen.
  5. Fearless1
    Fearless1 Active Member
    261
    Lemon fresh pledge leaves a no streak shine to windshield but won't do nothing for scratches.
  6. glider
    56
    It also makes critter removal much easier after you use it.
    I see I'm not alone here :D
  7. DougW
    DougW New Member
    what is the best way to clean the windshield? does pledge work to clean or after it ihas been cleaned?
  8. glider
    56
    Works wonders on the bugs. Just don't use it if the screen had mud or grit on it.
  9. Davidw2415
    Davidw2415 Senior Member
    1,456
    46
    I can relate Smitty. I have that disengaging brain condition quite often.
    But I wont embarrish myself my telling you some of the things I've done while my brain was disengaged. :p
  10. 4Bus
    4Bus Member
    6
    Hey everyone: Has anyone ever tried a product called "Rally Wax"? My father-in-law, who has been riding since he could walk, swears that it cleans and "de-fogs" all types of clear plastic and plexi-glass windsheilds.
