whinning belt drive
Discussion in 'Transmission' started by Del Boy, Sep 21, 2014.
  1. Del Boy
    Del Boy New Member
    After only 6000 miles from new I was told the belt and pulleys on my sportster were badly worn and needed replacing. Since this was done I have a whinning noise that appears between 40_50 mph. If I accelerate it disappears and also drop below 40. It has been rechecked by dealer and told it was somthing that happens with some belts. The only time it disappeared was when the dealer sprayed the belt with sillicon but came back after about a week. Is the belt too tight? The noise appears after riding for a short while so only starts once something wams up. Any tips on how to rid or something to put on belt.
  2. Jeff Klarich
    4,787
    103
    484
    In my opinion the belt and pulley should not have been worn to the point of replacement with only 6000 miles, something is wrong with the bike or your dealer. If it's making noise I do believe that's a sign the belt is to tight.
  3. Harttoo
    Harttoo Senior Member
    2,092
    140
    Belt at 6000 miles sounds fishy to Me.Did They show You the old belt?Was it replaced under warranty?Is this a Harley-Davidson dealer or an independent?
  4. fin_676
    5,775
    153
    284
    Belt a wee bit tight will make some noise often a squeak squeak squeak as you ride
    Once you start riding the pulleys will heat up and expand a wee bit this will tighten the belt
    Personally I keep the belt on my bikes a wee bit on the loose side with no adverse effects so far
    I have tried setting the belts with the correct Harley tool as directed in the service manual and get a squeak now I do it by feel as I mould set the tension on a chain
  5. DFHarley19
    DFHarley19 Active Member
    390
    Sound like your belt was too tight. Did you fix them yourself or dealer did that? If dealer did that then I would talk with service manager.
  6. Jack Klarich
    Noisey belt too tight have them check the action of the swing arm also and adjust the belt with a rider on it
  7. Del Boy
    Del Boy New Member
    The dealer replaced the belt and pulleys. Being new to Harleys (an old Brit rider)and knowing not much about modern bikes i took the HD dealer at their word. .the bike was owned for 18 months at the time so was out of warranty. Looking at the warranty it virtually covers nothing anyway. Will try slightly slackening off belt.
  8. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Do you ONLY ride on clean paved roads?
    IF not, and ride dirt, I would expect the problem.:(
    Putting on a new tire once out of town HD dealer on my 09 King: the mechanic said You have Damage to your belt... Looking, a little rock had gotten wedged in the rear sprocket and did SKUFF the belt.... No I said It will be fine... that was 80,000 miles ago.....Same Belt at 91,500..... Buyer Be Ware
  9. dbmg
    dbmg Guest
    Bubbie this is a on going discussion about dealers. If customer has not a clue the dealer will most definitely take advantage if they have a chance. Especially on items that could keep bike from running properly.
  10. Jeff Klarich
    4,787
    103
    484
    Thus my post, something wrong with the dealer. With only 6000 miles something tells me a major issue with the bike (unlikely) or the dealership is not to to be trusted.:nosad
