What states are checking motorcycles?
Discussion in 'Touring Models' started by Retrop, Oct 20, 2010.
  1. Retrop
    Retrop Active Member
    303
    3
    Tell us is you live in a state that is actively checking your motorcycle for sound or smog compliance when you get your annual inspection sticker. I am curious as to who is actually doing it today. I think it is on the immediate horizon for all of us. It will put a big time crimp in all the aftermarket mufflers makers and the fuel management device makers.
  2. Cyclops
    Cyclops Active Member
    371
    I can tell that Arkansas is NOT checking, nor is it a requirement. However, if your bike sounds too loud or if someone reports it as being too loud, it's up to the officer to determine if he/she writes you up. Pretty ambiguous to me. And you'd most likely spend more $s fighting it than simply paying the ticket.
    It's just a matter of when, not if, all states start testing or worse yet make owners pay to have it tested/certified prior to licensing.
  3. RetiredJake
    RetiredJake Junior Member
    862
    TN does not check. Some large cities do a smog check on cages, notably Memphis.
  4. HDDon
    5,542
    133
    229
    The state of Florida is not checking, but there are a few cities that are starting to implement sound ordinances.
  5. streitm
    streitm Member
    33
    Texas does not check either. Heck your inspection sticker is the same one that you use on trailers, and unless you go to a bike shop they dont even know what they are looking for most times.
  6. glimmerman
    glimmerman Active Member
    356
    Delaware definitely checks for noise. if you fail at 1 state facility and try to go to another on the same day, the computer picks it up and it fails automatically.
  7. dbmg
    dbmg Guest
    Most of the big name bike shops around Pittsburgh will not inspect if bike has drag pipes. Will not even pull it in to check the bike over till exhaust is changed. If things keep going like they are I would not be surprised if a Federal Mandated Emission Program is enacted like it was for car several years back. Basically no tampering with emissions so that it would pass emission test or possible fine up to $10,000 per occurrence. That put a quick stop to repair shops tampering with any emission components.
  8. sprinklerfitter669
    sprinklerfitter669 Junior Member
    982
    6
    Pa is not yet..
    some areas do have noise ordinances though
  9. soulshaker
    soulshaker Member
    57
    6
    Virginia doesn't check.
  10. HarryB737
    HarryB737 Junior Member
    656
    Not in NC... I would imagine California does...
