Voltage meter lying to me
Discussion in 'Electrical' started by zoood, Jun 11, 2010.
  1. zoood
    zoood Junior Member Product Contributor
    663
    5
    I checked the stator and it's output is correct. Did all the checks by the book. There's nothing wrong with it. When viewing my voltage gauge. At first it was keeping the battery at around 13+ volts. A two mile scoot down the road and it started reading 11 volts. When I brought back to the shop and did all the stator checks. Hooked it back up, started the bike and the voltage meter went back up to 12+ volts for a moment or so,... than dropped back to 11 volts. What the heck is causing this? Ive a trip to do Sunday and Ive a need to know right-a-way.
    50
  3. zoood
    663
    5
    I need another way to check that. Theres new oil in the primary and my sniffer doesnt work.
    seriously
  4. glider
    50
  5. zoood
    663
    5
  6. zoood
    663
    5
    Did check number two with DDM. Had voltage on both pins of regulator. I take it that mines the older type regulator? Has two wires (pins) going in and one out to battery.
    zoood
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Zoood, Is your system single phase or 3 phase. Check to see if you have 2 or 3 wire stator. Two wire is single phase.
  8. zoood
    663
    5
    If u mean from the stator plug. Its 2 wire
  9. zoood
    663
    5
    So I take it that since I had voltage at the pins. The regulator is no good?
  10. Hoople
    7,198
    34
    Ok. What is the condition of your battery. Has it been load tested recently. Would you know for a fact it is good. Can you crank the bike with the spark plugs grounded out for 10 seconds and the voltage does not fall below 10.50v or so?
    Does your digital volt meter have "diode test" on it. Meaning does it have an ohm range that has the little symbol for a diode.
