schooner
YOU'RE ABSOULUTELY RIGHT . . . About That My Good Man
Hey fin_676
Man are you right about watching out for the wrong moves I made during this tires/brake pad experience. I'm writing a log on all the I've done with my Harley and WHAT TO WATCH OUT FOR ~ To AVOID mistake I made in the past.
As far as new bolt (No) I put the small ones back; but cleaned 'em up and put loctite and torqued 'em down. Its not going anywhere. But THANKS - 4 - the heads-up on on all your suggestions. :bigsmiley12:
Hey fin_676
I think on your project of changing your tyres you have managed to hit almost everything that could go wrong
But once you have it all back together the sense of elation will be so much greater because of the problems you have encountered and over came
Next time it will be much easier because you will know what can go wrong and you will watch out for it
if you have removed and refitted the brake rotor and the pulley i hope that you have used new bolts and used loctite on the bolts and torqued them to the correct torque as you dont want them breaking loose as you go down the road
i had a pulley come loose once no loctite on the new bolts
