Trying To Mount My Rear Wheel . . . '85 H-D
Discussion in 'Touring Models' started by schooner, Mar 31, 2011.
  1. schooner
    schooner Member
    41
    1985 Electra Glide Classic Rear Wheel Mounting ...
    Hey Guys ( Newbie Still Learnin' )
    I'm in trouble again guys - Mounting the rear wheel ~ NEED HELP ON THIS ONE
    Here's the problem so far.
    I can't get the rear wheel into the BRAKE CALLIPER
    I have new brake pads also for the rear and front of the bike.
    My bike is: '85 Electra Glide Classic
    1. Do I have to disconnect the entire brake assembly in order to get
    the rear wheel on the bike ?
    2. Should I replace the brake pads FIRST and then try to get the rear wheel
    back in the brake caliper ?
    HELP GUYS
  2. BOBFLHTC
    BOBFLHTC Active Member
    273
    I've had the rear wheel off several times and have never removed the rotor. Check out this link:
    Removing Rear Wheel - Harley Davidson Community
    You might have to spread the pads with a pair of channel locks and especially if you install new pads. Have you changed the break fluid ? A whole new can of worms - Bob
  3. karlsbike
    karlsbike Active Member
    264
    3
    Hi again, Schooner
    Two problems, as I understand:
    1. Try to lift the wheel in at an angle (or lower the the bike while holding the wheel at an angle); you need to get the tyre past the caliper, and then you're good to go.
    If that doesn't work, you can just losen the caliper bracket and get the tyre past the caliper, then put the bracket back in position.
    2. Replace those pads first, and then you need to push the pads apart to fit the disc. I use a clean, XL blade screwdriver - push it in, and twist. Now this should be done firmly but gently, and leave time for the brake fluid to be pushed up into the reservoir. Oh yeah, make sure your reservior is not full when you start off.
    I like those pictures of yours - it makes us (at least me) want to help out...
  4. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    Like Karl said, you need to get the brake pistons pushed back into the caliper to allow for the thickness of the new pads. The pistons go in slowly, just keep pressure on them. I use shims of tin to prevent gouging the new pads with the screwdriver, or tap a wooden wedge slowly between the pads. Once the pads are far enough apart for the rotor to fit, I slip a wedge made of spring type clothespin halves between the brake pads, towards the front. The wedge keeps the pads firmly separated, and as the rotor goes between the new pads, it pushes the wedge and they fall out.
  5. Dr.Evil
    Dr.Evil Junior Member
    694
    5
    Had this same problem wrestling it by myself. I removed the pads and it fell right in.
  6. karlsbike
    264
    3
    And that would be the pro version of what I do - thanks for the tip, I'll try that next time.
  7. fin_676
    5,776
    153
    284
    I pull the caliper off on my bikes before removing the wheel and put it back on when the wheel is mounted back on
  8. btsom
    btsom Active Member
    351
    38
    I do the same, and especially with the pad change, that would make everything easier.
  9. schooner
    schooner Member
    41
    You're Not Going To Believe What I Did ! ! ! !
    Hey Karisbike (Stupid Here) :newsmile026:
    This is a WARNING to all dump guys like me.
    Check this out.
    I broke my hump getting and squezzing in the brake calliper and the brake pads to fit on the rotor. I tightened everything up and was proud of myself.
    Do to the fact I NEVER changed a motorcycle rear tire before or installed new brake pad. Man, I was beat and sweaty.
    I sat down near my rear wheel on a small plastic stool. My view of my newly mounted rear wheel was just a bit below my eye level.
    I happened to look at my tire. And what did I see? I MOUNTED THE TIRE '' BACKWARDS " the tire thread going the wrong way :small3d031:
    I attached the spocket on the WRONG SIDE OF THE REAR TIRE. ROTO DISC WAS ON THE WRONG SIDE ALSO :wall
    I couldn't believe what a DUMB mistake I made. So off comes the spocket and the rotor disc. I re-attached the spocket on the correct side of the wheel MAKING SURE THE TIRE THREAD was going in the RIGHT DIRECTION.
    By this time I was DEAD TIRED. i just laid the rear tire near the bike and I'll tackle the mounting of it tomorrow. That's if I don't die in my sleep !
    So guys be forwarned: DON'T DO WHAT I DID. LOOK @ THE DIRECTION OF THE TIRES BEFORE YOU MOUNT 'EM. Its a tough lesson on my part. However, I assure you guys IT WILL NEVER EVER HAPPED AGAIN ON MY PART.
    I'm done :(
  10. fin_676
    5,776
    153
    284
    I think on your project of changing your tyres you have managed to hit almost everything that could go wrong
    But once you have it all back together the sense of elation will be so much greater because of the problems you have encountered and over came
    Next time it will be much easier because you will know what can go wrong and you will watch out for it
    if you have removed and refitted the brake rotor and the pulley i hope that you have used new bolts and used loctite on the bolts and torqued them to the correct torque as you dont want them breaking loose as you go down the road
    i had a pulley come loose once no loctite on the new bolts
