True Dual Kit 2.0
Discussion in 'Engine, Fuel and Exhaust' started by Bud White, Jan 25, 2009.
  1. Bud White
    3,270
    Ok last bit of Assembly done.. now when it warms up ill fire it up check for exhaust leaks and put the shields on
    Here is the little bugger that caused the Delay
    [​IMG]
    Pic of the cylinder with Gasket out
    [​IMG]
    now gasket in
    [​IMG]
    Then the header pipe do not tighten at this time just put in place and finger tighten down the flange nuts
    [​IMG]
    Now to fix up the left side pipe .. if you look closely its out of round they really reef down when tighting this clamp .. the kit comes with another small pipe they call a mandrel but hey its a piece of pipe you hammer in to true up the pipe .. coat the mandrel in wd-40 goes in easier .
    [​IMG]
    Install the now trued up pipe Do not tighten down
    [​IMG]
    Now install the slip on
    [​IMG]
    Start tightening down your clamps tighten the trans mount clamp last after tighting this nut down
    [​IMG]
    That is the old pic the new one you need a swivel socket to tighten it down and ya can't really see it
    Tighten this clamp last its the one that holds the stud that mounts to the trans
    [​IMG]
    And there is the True Dual Kit not hard to do if your interested in doing it .
    Little bit harder when its around 15 degrees for the whole install
    Hopefully it might help someone
    [​IMG]
  2. Ken S.
    Ken S. Active Member
    270
    Awesome, Bud, you gotter done. No wonder you had a headache if you were in the garage working in cold weather. Of course, my boss had me working outside two weeks ago when it was -17. Heartless. But then again I'm outside working everyday so....
  3. Bud White
    3,270
    im used to working outside used to do it all the time i was in a tshirt working .. not sure what started headache was like somthing poked me in the eye came on sudden .. its done for now till i can get it warm enough to start
  4. Bud White
    3,270
  5. Bud White
    3,270
    Thanks Smitty
  6. glider
    50
    Bud
    What mufflers are on there?
  7. Bud White
    3,270
    They are from the same place i got the pipe from.. Didnt know if i could say or post a link
  8. glider
    50
  9. Bud White
    3,270
    yep they are replacements they tell you you can't run the stock Slip on's with the true duals. Just like it says in your tip posted above
  10. sharpscuba
    sharpscuba Banned
    945
    Love the sound Bud...nice work,did you find the water source?
