I recently purchased a a motorcycle that was a basket case. :devil I have had nothing but problems with a so called a good parts. Now that I have the motorcycle together, I find that the transmission will not shift properly.
It feels as if the racket part of the shifter is not working. My first thought is that there is a spring off or something like that. I can get it to go into different gears but I must shift it back and forth many times to get it from one gear to another. There is no noise coming from the transmission so I am rather convinced that the gears are OK.
The neutral light switch does not seem to be working either. I have never even looked inside of the transmission before. So I am at a loss of what to do. Or what to even look for.
If anyone out there can give me some ideas what it may be I would appreciate it.:cheers
