BUBBIE
Well-Known Member
New 2012 FLHTK Limited 119 miles Trans is rattling in neutral. Any info on this?
Sure it is the tranny????
Sounds more like the Primary Chain from here. It will make the Rattle IF the adjuster IS Not tightening it up....
New off the show room floor, My 09 FLHR needed to be "Jostled"
In gear riding (I like 2 or 3), with throttle open enough to PULL while the rear brake it TAPPED hard... This produces the tension on the top of chain and the bottom will (or should) tighten.....
Many new bikes need to be Reminded that this tensioner in the primary IS automatic...
Give above a try and report back..
You know all the WARNING Labels Needed Here.. Don't side the bike and wreck the bike And Yadayada..
