Trans Oil
Discussion in 'Oil' started by glider, Oct 14, 2007.
  1. glider
    56
  2. wtroutt
    wtroutt Member
    35
    18
    Hey Glider...does that oil work with the 6 speed and how does
    it improve with the reported noises?
  3. wildspirit97
    wildspirit97 Guest
    you still runnin' mobil 1 in the engine?
  4. glider
    56
    It works well in the 6 speed, the IDS system took care of all the noises in the trans and this oil made it even smoother than it was with the M 1 that I was using. I have used the redline also in the past and I think this has it beat. It just seems so much smoother and I'm not an easy sell on anything.
    It's 75/140 but it seems as if the clutch plate drag associated with the other 75/90 or the 75/140 Mobil 1 is eliminated. Shifts smoother and with less of a clunk. Neutral is a snap now too as compared to the M 1
  5. glider
    56
    Yes, still have the M 1 20/50 synthetic in the engine.
  6. DYNAGUY
    DYNAGUY Active Member
    123
    I like RedLine heavy . Made a bit of differnce in my 07 WG
  7. glider
    56
    I used redline heavy for quite a while till I tried this oil. I'm sticking with this one for now.
  8. Fourdogs
    Fourdogs Junior Member
    805
    3
    Glider..Have you ever used Royal Purple?....i tryed a few and found it to be very good...in the Transmission I'm speakin of..
  9. glider
    56
    I have never used RP but the guy who told me about this oil had used it and he switched to Spectro too so I was going by his recommendation and based on the oils that I have used in the past which have been many , I feel this is the best so far.
  10. docholliday88
    docholliday88 Member
    89
    if you don't mind me asking what would you recommend in the 5 speed on an '06 XL1200R?
