Tire Inflation Pressure
Discussion in 'Softail Models' started by McQueen1963, Jul 24, 2009.
  1. McQueen1963
    McQueen1963 Active Member
    149
    Hi.
    Three months ago I bought my 2005 Softail Heritage Classic. The previous owner did not have the owner's manual. So I'm saving to buy the service manual. Here in Mexico, is very expensive and the dealer delivers it in two months so I buy it in somewhere online store in the USA. meanwhile, I got a service manual on DVD ($15.00 bucks). The manual is good, but I have a doubt about TIRE INFLATION PRESSURE. . In the DVD there are two sets of data. Which one is correct?
    PSI
    Front wheels
    Rider only 30
    Rider and passenger 30
    Rear wheels
    Rider only 36
    Rider and passenger 40
    Front wheel
    Solo 36
    Rider and passenger 36
    Rear wheel
    Solo 36
    The front tire of my Softail is a Dunlop D402F , the rear one is a Dunlop D401
    Thanks in advance
  2. walleye
    walleye Junior Member Contributor
    944
    3
    It will say on your tires what PSI to put in them. Follow that and be sure tire is cold when checking. You will be fine. It is the tire that makes the recommendation not the bike.
  3. glider
    50
    Sidewalls on tires are the MAX pressure, not the recommended pressures.
    This one is correct.
    Front wheel
    Solo 36
    Rear wheel
    Solo 36
  4. walleye
    944
    3
    Glider, is it better to always run under the max rating? I have always been using the listed PSI in the past.
  5. glider
    50
    If you inflate to the max on the side wall, when it heats up you can add 3-5 LBS of pressure to that. Add that up and see where it falls into line with the recommended pressures in the manual for the bike which is what I use.
  6. McQueen1963
    149
    I got it!
    Thanks a lot to all of you
  7. just4u
    just4u Banned
    107
    Howdy, I can't let this subject pass without sharing this. I just bought and in stalled Avon Venom X am42 77v on the rear, and avon Venom x am41 74H on the front. I also just loaded up my ride ( 06 heritage) for a 2700 mile road trip. the bike is a little un stable with a extra load. so I called Avon, they told me to increase the tire psi front to 42 psi, and to increase the rear to 48 psi. the tires came with a spec sheet for tire psi for heavy load that said to set the front to 42-43 psi, and the rear to 48-50 psi here is the kicker. The side wall of the front tire states" max psi cold 40, and the rear states max psi cold 42" so who is right the tire tech people or what it says on the tire?????
    I set the psi to what the tire tech said and the bike handles great.
  8. NEWHD74FAN
    8,191
    98
    19
    McQueen, your second set of numbers is correct...
    Front wheel
    Solo 36
    Rear wheel
    Solo 36
    Check your front frame decal, it lists the stock tires & wheel recommended tire pressures...should say the same.
  9. just4u
    just4u Banned
    107
    NEWHD74FAN, what about avon's mixed up psi specs??
    J&P cycles where I bought the tires gave me the correct answer. Go with what is says on the tires, Max weight, Max psi cold. The avon tech person must of thought I was talking about the reinforced tire, and I have the venom-x non reinforced tire. venoms do not handle well loaded up for a road trip. oh well, it is what it is, next time it's a Mez or dunlop. I just want to share this so nobody else puts the worng tire on thier bike.
  10. 2wheels4life
    2wheels4life Member
    20
    I always run max inflation regardless of what bike or tire. I feel I get the best performance this way and maximum life. Some manufactures recommend this as well.
