Not ignorant at all.
qbert1963 said it best with using your finger. This eliminates the other instructions. If you get the "pssssst" (sound of compression) as the piston reaches TDC, then you know you are on the right stroke and then see if the timing marks line up. They should unless something is really wrong. Quick way of verifying things without checking the pushrods.
