start up noise
Discussion in 'Engine, Fuel and Exhaust' started by hargun2, Jul 13, 2010.
  1. hargun2
    hargun2 Member
    84
    I have a 02 Standard thats clacking on start up then the noise goes away after it's warmed up. I have removed and replaced the lifters and readjusted the pushrods, no change, sound like it's coming from the rocker box area of the front cylinder. Ideas?? P.S. it's carberated and when I let it idle down below 1000 rpms it really clacks...
  2. Jack Klarich
    Are the lifters pumping up , have you checked oil pressure and cleaned the overhead tappet screen?
  3. hargun2
    hargun2 Member
    84
    have not checked the oil pressure or cleaned the tappet screen. Not really sure where to start with this issue since the noise is coming from the cylinder head area. How would I check if the lifters are pumping up at start up?
  4. Jack Klarich
    Recheck the pushrod adjustment first, do it cold, could be the problem:s
  5. TQuentin1
    4,737
    142
    Clean that tappet screen. You should do this at each oil change at least. If this is partially plugged, it limits the flow of oil to the lifters.
  6. Jack Klarich
    The tappet screen is way too often over looked, cheap insurance to check and or replace it . It traps junk from plugging up the feed to the pushrods and getting oil to the top end:s
  7. hargun2
    hargun2 Member
    84
    ok I will check that screen tonight. I put a set of SS push rods in and the installation instructions say to turn them out 2 1/2 turns with the cylinder at TDC. I read a few weeks ago on this forum that 32 threads per inch rods guys were recomendeing 4 to 4 1/2 turns from Zero back lash...??????
  8. Hoople
    Hoople Account Removed
    7,198
    34
    Be sure your at TDC of the compression stroke and not TDC of overlap or Exhaust stroke.
  9. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I didn't know a 02 TC had a tappet screen.... What have I missed all these years?
  10. Jack Klarich
    If its a twin cam it wont have a tappet screen, Bubbie is right:s
