Springer question
Discussion in 'Softail Models' started by jdgreen454, Jan 19, 2010.
  1. jdgreen454
    jdgreen454 Member
    21
    Looking at buying a 2006 Springer Classic from a buddys dad. Bike is flawless with only 2500mi on it. Question I had was how often does the frontend need serviced? I read somewhere they should be checked over every 2500mi or so. Is this accurate info? Thanks
  2. RUSHMORE_14
    RUSHMORE_14 Junior Member
    538
    heard the same thing......i think they need to be greased.
  3. Bud White
    3,270
    easiest way check the owners manual or repair manual if he has it .. or if you can get the VIN # plug it into harleys site under check up and it will tell you what needs to be done .. you can plug in different mileage to see the various stuff
  4. Chopper
    Chopper Senior Member
    1,632
    19
    They are a high maintenance front end but I think the cool factor fair out weights it. The service manual maintenance calls for the rockers to be checked and adjusted if needed first service (used to be 500 now I think they let you go 1,000) and every 10,000 miles there after. Don't skip doing it, the front end does need it.
  5. jdgreen454
    jdgreen454 Member
    21
    I just read on another site that Harley recommends every 2500mi. If someone is positive please let me know. Thanks
  6. Chopper
    1,632
    19
    This is right out of a 2006 manual, you were right about lube & adjusting head bearings 2,500, then rockers every 10,000 and Disassemble & inspect head bearings every 20,000 miles, I apologize I'm always sure about what I post, but am I always right, do pigs fly:small3d023:
    [​IMG]
  7. Bud White
    3,270
    thats a lot of upkeep on that front end
  8. Mattman4403
    Mattman4403 Junior Member
    602
    But they do look good.
  9. Chopper
    1,632
    19
    Yea but how hard is it to pump a little grease & do a fall away every 2,500 miles when you have a good handling front end with a cool factor that goes through the roof?
  10. NEWHD74FAN
    8,191
    98
    19
    Keeping things in perspective, that is between 1 to 2 years for most riders for servicing front steering head bearings and such, verses 2-3 years...! But such is the way of "classic design" I suppose you could put in more durable bearings and races in the front end (they are hidden anyway), but that is the nature of the beast.
