Spark plugs for 1340 shovel?
Discussion in 'Classic Models' started by FxRs-John, Mar 31, 2009.
  1. FxRs-John
    FxRs-John Member
    19
    Anybody know of a decent spark plug for my 82 FXRS? Not having to much luck with the HD ones. any help would be appreciated.
    50
    What is the problem with the stock ones from HD? Are they fouling? What number are you using? What gap?
  3. FxRs-John
    FxRs-John Member
    19
    the rear one keeps loading up with oil residue, but other than that no problems. Talked to a very experienced machinest in my area, Ed VanEss, he is the one who started double plugging heads around this area, he says used to use autolites but i cant seem to find any at the automotive stores in town.
  4. glider
    50
    You probably have an oil control problem that should be addressed in the rear cylinder. Going to a hotter plug in that cylinder may help but it's only a remedy and not a cure. Plugclub.com can send you any plug you need.
    NGK Spark Plugs Denso Spark Plugs
    The plug in autolite is [FONT=Arial, Arial, Helvetica]2585[/FONT]
  5. softailsteve
    softailsteve Active Member
    107
    sounds like its time for at least a top end if the 2585,s dont work
  6. Fossil
    Fossil Active Member
    335
    I think as usual Glider has hit it on the head. By the way, when is the last time you replaced the spark plug wires? Fossil
  7. Caper
    Caper Active Member
    236
  8. FxRs-John
    FxRs-John Member
    19
    I know that the the rings need to be redone, the guy i bought the bike from informed me that he had just gone through the top end. So he either didnt know what he was doing or hes a big liar. I have heard quite a few people say that autolights were the best pulg to use in shovel heads. Just trying to find out if this is true or if there is somthing better out there.
  9. Caper
    Caper Active Member
    236
    As long as you have a bright sharp blue spark, doesn't matter what plug you use. The iridium plugs I was told will give a quicker start,(this was on a 17:1CR race engine) and they'll last longer,but are they worth the extra money???...IMO, no...none give more Hp. The only plug I would not use are the Champion plugs made in Mexico, they're junk....the ones made in the US are as good as all the others.
  10. mrkihn
    mrkihn Active Member
    172
    I used to run splitfire in my old 84 shovel and didn't have problems with them
