Screaming Eagles
Discussion in 'Softail Models' started by Slipkid, Apr 26, 2007.
  1. Slipkid
    Slipkid Member
    12
    I just bought my bike, a 2007 Softail Deluxe, and had Screaming Eagles (slip ons) installed. To be honest I'm disappointed in the sound. There isn't any!
    What, if anything, can be done?
  2. AoXY
    AoXY Active Member
    176
    Installed customized pipe should help you get sound what you want dude.
  3. XL1200N
    XL1200N Frozen Account
    136
    Pull out the baffle or drill 'em out.:eek:
  4. Slipkid
    Slipkid Member
    12
    First, thanks for the reply. Secondly, will drilling out the baffles harm the valves?
  5. XL1200N
    136
    No...you will need to install High Flow air cleaner and adjust fuel air mixture though.;)
  6. Hi-Tek Rednek
    Hi-Tek Rednek Active Member
    127
    Try these Slip-Ons, you'll not be disappointed. " RUSH " slip-ons. Go under Google and type in : RUSH slip-on exhausts. It'll give ya a website to research them on.I've seen and heard a sey and they were very impressive for a set of " slip-ons". Take it easy, Hi- Tek Rednek
  7. glider
    56
    The new slip on's from HD fall short in the sound department. If you had a pair of the older SE II mufflers, then you would have a great sound. The rush mufflers offer different size baffles but if you go over 1 3/4 baffle you loose the required back pressure needed in the FI engines and loose torque.
    Here's the home page for rush mufflers http://www.epiflex.com/
    I would be carefull about over doing the drilling on your present baffles. It's easy to drill them out too much and loose performance at the expense of more sound.
  8. whitefatboy
    whitefatboy New Member
    I had SE installed with my bike, and I have to say, they sound very good...(LOUD). Are there different types of SE? Maybe I have "offroad type"?
  9. glider
    56
    The SEII slipons are the good ones, the newer ones are EPA compliant.
  10. wildspirit97
    wildspirit97 Guest
    I got a brother who has a set of rush slipons,high flow air cleaner with the S.E.R.T. on his 2007 fxstc. I'm not sure what model on the mufflers, they're slash cut out, but they sound good, his bikes fast, and get about 45 mpg.
