It may be simple, but it isn't a fast job to do.
Start off by removing the left foot peg and shift lever.
Next, drain the primary.
Then slack off all the pressure on the primary chain adjuster. Remove all the primary cover bolts and pull the cover off. Slack off the tension on the clutch cable where it threads into the case and pull the top end out of the handlebar lever once this is done.
Unhook the lower end of the cable from the actuator arm, being careful not to let any of the 3 balls fall out of the ramp assembly. Remember how this looked!
Unscrew the cable the rest of the way out of the case. When you put it all back together in reverse order, more or less , you'll have to install a new primary cover gasket, adjust the clutch and primary chain, and put fresh fluid in the primary.
Let's not forget to lubricate any cables when they are apart also.
All in all it's not a hard job to do, only takes a bit of time to complete.
You should also have a factory service manual available for the torque on the various bolts also.
