As your oil wetted clutch resides in there, I just make sure there is good quality lube in there, that is not 100% Synthetic...just a holdover from my metric days and in my Sporty since primary, trans and clutch are one in the same I end up using Spectrol Primary Chain & Tranny lube, it is safe for clutches. If you insist on using motorcycle oil I choose not to use Syn3 and use a fine quality MA (Motorcycle Rated OIL approved by manufacturers) that is safe for oil wetted clutches, (metrics use 1 hole for all three, imagine that picture)!
