Primary gasket replacement trick
Discussion in 'Touring Models' started by steveohdrider, Mar 15, 2010.
  1. steveohdrider
    steveohdrider Member
    When I replace the primary gasket on my 04 Road King Custom Sport I found an easy method for installing the gasket. This method will keep the gasket aligned perfectly and eliminate damage as well to the new gasket. In addition will keep the gasket in place or from falling off when intalling the primary cover.... Use the longest primary bolt and match at any hardware store and match size with 4 ea. shouldered bolts aprox. 3" long and cut off the heads and then file smooth.. Now use these bolts temporarily and thread them by hand at at top, right, left, right and bottom of case and simply slip new gasket over the bolts, Note: shoulder protects gasket and the primary cover. Now install the primary cover and intall the factory bolts as specified, remove the temporay bolts and replace with factory bolts. No more dropping the gasket perfect alignment and fool proof install every time. I have no more problems with primary gasket replacement. This method works on other HD model as well.
    1 person likes this.
  2. HarryB737
    HarryB737 Junior Member
    656
    Great Tip Thanks!! :)
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Awesome idea. Tks!
    Would you happen to remember the thread size and pitch that you purchased.
  4. HarryB737
    656
    Our local Home Depot or Lowes have pattern holes & studs to check the sizes, just take one of the originals with you. In resent years they are even carrying Metric sizes... Yahoo!! :D
  5. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    Great tip. My 09 has 2 dowels on the inner primary case and the gasket and outer primary case sit on them for alignment.
  6. steveohdrider
    1/4 inch 20 or 20 threads per inch..
  7. Butch
    Butch Active Member
    227
    Great tip - deceptively simple, yet so effective. Thnx for sharing.
  8. Dr. Dolittle
    6,404
    118
    29
    As most great tips seem to be. Once you hear them and/or try them it's so obvious you wonder why you never thought of it!
  9. Jack Klarich
    See, another great tip thats whats great about this site, Thanks for the tip
  10. krazy3
    krazy3 Member
    75
    Thanks for the tip!! :)
