Primary drain plug, I dont understand an issue with it
Discussion in 'Sportster Models' started by BillMull, Aug 15, 2011.
  1. BillMull
    BillMull Banned
    71
    96 Sportster and I drained the primary fluid and the plug was pretty tight to even get off. When I put the fluid back in it and put the plug back in it I was tightening it and it seemed to never get tight but just spun around constantly. I looked through other "threads" in regards to this and never found anything regards to the model bike I have. I just want to make sure if this is common or anyone else who has this bike or anyone who just knows about this issue. Im tired of running into issues with this bike. It has been one thing after another with it. I guess its part of it when getting it from someone who didnt have a desire to maintain it as I love to! Thanks to everyone!:cheers
  2. brownfoxx1
    brownfoxx1 Active Member
    262
    see sept,2011 popular mechanics mag. pagers 139-141 it uses a lisle 58850 oil pan plug rethreading kit. avail at napa. $95.00 good luck
  3. dbmg
    dbmg Guest
    I would think a drain plug has to be able to be torque to a certain spec. Go get a new plug at dealer and see if it will install properly. If not then brownfoxx1 has you covered. Sounds like it was crossed threaded last time oil changed.....:(
  4. Jack Klarich
  5. TripleJ
    TripleJ Senior Member
    1,081
    8
    As usual Jack is spot on. Bill I happen to have a Time-Sert kit that may work for you if Jack or someone else can verify if your primary drain plug is the same as what I have (1/2-20). I will send the kit to you you so you can do the repair the right way but have to send it to geezer when you are done as he has dibs on the other insert left in the kit.
    2 people like this.
  6. Jack Klarich
    TripleJ always willing to help, Awesome , Me thinks you have the correct kit:s
  7. brownfoxx1
    262
    they also make a steel threaded reducer you might consider. i used to use it for the petcock in the gas tank to accept a different size petcock. if you epoxy the reducer in then the plug will go into a steel threads. just trying to give you options.
  8. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    Thanks for still thinking about me John but it sounds like Bill needs the kit now so send it to him if you wish. My tranny plug will be good till winter. :D
  9. TripleJ
    1,081
    8
    Only sending it to Bill if he agrees to pass it on to you :D I have a funny feeling he will :bigsmiley14:
  10. geezer
    1,709
    68
    73
    I'm sure he won't have a problem with that. By the time you get the kit back there won't be any inserts left!:lolrolling
