Primary Chain Adjustment
Discussion in 'Sportster Models' started by JohnnyBiker2, Jul 19, 2010.
  1. JohnnyBiker2
    JohnnyBiker2 Member
    93
    Hello to everyone, I am JohnnyBiker2, I have just joined this forum and I am looking forward to meeting all of you.
    Well, let's get to it. I have a 96 Sporty and I need to adjust my primary chain. I have a book but it just (edit) (Try's to cover too may bikes). Please correct me if I am wrong, I need to take my inspection cover off, or fill cover, check the deflection through there, I am looking for a deflection of no more than a 1/2" cold, and no less than 3/8" cold? Now here is the thing that is just driving me nuts, on the bottom of the primary, there are 2 bolts, one that is just a hex, I am assuming that this is the drain? The other has a hex nut, but seems to be hollow with an allen in it. The one with the allen is my chain adjuster right?
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Johnny, Your not off to a good start. You will see why shortly.
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    YES..... the one you described is the chain adjuster....
    Mind You,,,,,, This adjuster for your sporty is Just as "Touchy as OUR Language rules" so careful when you adjust and tighten and Speak.
  4. JohnnyBiker2
    JohnnyBiker2 Member
    93
    I guess I should not have used that S word. My apologies.
  5. R. Lewis
    2,183
    5
    You guessed right!!
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Welcome to the forum Johnny; When you adjust the chain it's a good idea to turn the engine over and check several different spots. Chains sometimes have tighter/looser spots in them.
  7. JohnnyBiker2
    JohnnyBiker2 Member
    93
    Again, my apologies, this will not happen again. :D
    have you noticed that the inspection cover on them don not seal the same all the way around? Why do you think this is?
  8. glider
    50
    Usually because someone tightened it too much and bent the inspection cover.
  9. JohnnyBiker2
    JohnnyBiker2 Member
    93
    It is a good thing that I will be putting a different on anyway. Update I took a look at my chain, and I thought that it was dead on. Just to be sure, I took it to an indy shop that is three blocks away and they had said the same thing, so I guess that is not what I am chasing. This is baffling.
  10. JohnnyBiker2
    JohnnyBiker2 Member
    93
    Well, at about 40mph, I would start to here this noise. I guess the noise is best described as what I would described what those road gremlin bells sound like. I spoke to an indy shop and suggested that it is most likely my chain was loose. As said, I checked the chain, had a different indy shop look at it, and they said it was ok. So now I am just curious as what the noise is? Any suggestions?
