Oil Filter Poll
Discussion in 'Oil' started by glider., Oct 26, 2007.
Oil Filter Poll
  1. HD Filter
    687 vote(s)
    62.1%
  2. Amsoil Filter
    85 vote(s)
    7.7%
  3. Wix Filter
    37 vote(s)
    3.3%
  4. K&N Filter
    162 vote(s)
    14.6%
  5. Napa Filter
    12 vote(s)
    1.1%
  6. Fram Filter
    47 vote(s)
    4.2%
  7. Purolator Filter
    18 vote(s)
    1.6%
  8. Hastings Filter
    0 vote(s)
    0.0%
  9. Mobil Filter
    13 vote(s)
    1.2%
  10. OTHER (Please specify)
    46 vote(s)
    4.2%
  1. glider.
    glider. BOT Machine
    18
    Let's see what's being used as far as oil filters.
    Feel free to give your comments on it also but please post in the proper forum for asking a question about filters. This section is just for gathering info on the filters themselves.
    Also take a look at the filter comparisons here.
    Oil Filter Comparisons - Harley Davidson Community
  2. Not Very PC
    Not Very PC R.I.P
    527
    HD oil Filters
  3. wildspirit97
    wildspirit97 Guest
    mech. at the shop said k&n was better.....it was a dollar more, don't really care about that, and I don't know how to tell if one filter is better than another, and don't know if he can either...but I liked the nut on the end of the filter. guess now i don't need my "special" Harley oil filter wrench with the notch cut in the side.:rr
  4. glider
    56
    I've always used the HD filters because I feel the HD filters were specked for the engines by the manufacturer even thou it probably goes out to the lowest bidder to be made, the company still has to stand behind them if a problem pops up. That's all the dealers would have to see if you are still under warrantee is a aftermarket filter. They could give you a hard enough time without you furnishing the ammo for them.
    There is a big difference between filters of different brands. The bypass spring in itself will allow the oil to circulate unfiltered if it isn't the proper opening pressure, not to mention the filter media size and the make up of the filter itself. The nut on the K&N is nice but I still lean towards the HD filters, I sleep better at night:D
    Take a look at this post, especially the first link...
    http://www.hdtimeline.com/oil_related_tips/903-oil_filter_comparisons.html#post4339
  5. DYNAGUY
    DYNAGUY Active Member
    123
    I must be keeping Amsoil in bussines. I am only one voted on Amsoil filter.
  6. glider
    56
    The biggest problem with amsoil products is getting them, especially on the road if you need some while away from home. The popular brands are available in most auto supply houses or at a HD dealer.
  7. Spike King
    Spike King Member
    64
    K&N filter for me the nut on the end makes life alot easyer they cost more tho :x
  8. Deus ex Machina
    Deus ex Machina New Member
    I use and have used Perf-Form synthetic filters for years now with zero complaints.
  9. jimmykayla
    jimmykayla Member
    19
    Amsoil filter and oil for me!!...and I know alot of people that swear by it!!!
  10. 07ROADKING
    07ROADKING Active Member
    120
    i use the 5
    micron H-D filters i will switch to ams oil filters after the warranty is up:s
