Ok so I know I said I was satisfied with just the cam upgrade but it bit me and I tore down the bike and sent the heads off for porting and new valves. Can someone tell me a good way to properly seat new valves?
NOTHING OVER 9,000 RPM for the first 1,000 miles...:lero
That would be My Way...
ask if they replaced the Guides with Bronze or kept stock...? Just for information. Bronze will Out-Last stock guides.
I suspect with the work you identified, that you may have changed the rings too. Those do need a bit of a process to make sure they are seated. Check this out:
Harley Davidson Forums
Cheers,
If the valve job was done correctly, checking spring height and pressures, ride it like Bubbie said:s
No rings but it is tempting to go big bore since its just sitting there naked on top!
