New Bike, Neglected Bike?
Discussion in 'Engine, Fuel and Exhaust' started by toddincharlotte, Mar 29, 2015.
  1. toddincharlotte
    toddincharlotte New Member
    4
    I just recently picked up a 2008 XL1200C locally. Bike is in really good condition cosmetically but I noticed it misses at 1/4 throttle and less. It only has 6k miles logged on the odo so I'm thinking I may have some bad gas, maybe even a bad tank.
    Looking for suggestions on what kind of special maintenance I can do to try and fix this. Also, any suggestions on how to understand whether or not my gas tank is rusted is appreciated.
    Was going to just start with fuel treatment but I worried if there is rust or debris in the tank I could damage the fuel pump or FI.
  2. Bodeen
    4,643
    73
    221
    Not familiar with Sporty's but some Seafoam cant hurt to start with. With the tank empty or nearly empty you should be able to shine a light down in it and get an idea of its condition.
  3. Jeff Klarich
    4,802
    103
    486
    How long has it been sitting with the gas in the tank? As Bodeen suggested, inspect it best you can and if you think it's dirty inside remove and clean. A healthy dose of sea foam with clean gas will go a long way in cleaning things out.
  4. Jack Klarich
    If you can get the fl[​IMG]oat bowl off the carb and clean it out that will help also
  5. toddincharlotte
    4
    Thanks for the suggestions guys. I think I will do some seafoam and a little gas swirled around and dumped. Does anyone know if there is a fuel filter inline before the FI?
    Jack,
    From 2007 on the sporties got fueil injection.
  6. Jack Klarich
    My bad, I saw the avatar and did not read you were talking about an 08
  7. toddincharlotte
    4
    What I observed this afternoon was that it runs fine until warm and then misses once fully warmed up. It's not a really bad miss but I can tell the bike us not running at full power when warm.
  8. Jeff Klarich
    4,802
    103
    486
    Your miss may or may not be fuel related. New plugs and wires may not hurt.
  9. Bodeen
    4,643
    73
    221
    Not sure about Sporty's. Do they have a temp sensor in the head that makes it do parade mode or some such event?
  10. T in Texas
    T in Texas Member
    35
    I also picked up a 2008 Sporty in Jan of this year. It did the same thing. But I found out in this site that since it has a stage 1 intake and free flow exhaust I needed a fueler. It fixed it. I went through plugs, plug wires, IAC, New K&N Filter and some stress! A Cobra Fueler made the difference. Yours with the low miles must still be stock exhaust and air. if so, it will be something simple, finding it is the problem. Good luck my friend.
