105annivdyna
I'll pull it tomorrow..
its the reason i will never have a 110 motor to many issues
the axtell barrels are awesome but if i was going to case bore i would go the whole way and fit the 124 from S&S![]()
I'm not saying you don't have a problem, but I've had a couple of new harleys, that I thought I had a oil usage problem, that didn't. One thing I did was mark the dipstick and always check it when it was cold. Checking it at differenet operating tempertures can make a big difference on the stick. Another is always check it when the bike is in the same spot, like in your garage. Sometimes when your checking your oil away from home, it may look like level ground, but it might slant somewhat giving you a false reading. In my case, after checking oil cold and making sure the ground was level, my oil usage was a lot less than I first thought.
Hope this helps Jonnierock
