My thoughts are : I also agree with the above...
If your bike and the area you are in,,, allow the rpm to go lower ON COMPRESSION is not lugging. The motor will tell you if it is... The older day bikes , it was common practice to shift to a Higher gear when using compression as not to put strain on the WEAK shoe holding the primary chain... I never saw anything in Print but I have always liked going down a long grade at less than 2900 RPM... 1800 with a tack. but ONLY on occasion...
YES, IT can be dangerous to have your Power Band so low.... ONLY on occasion do I do this Today on my bikes... Not for the shoe that holds the primary chain,,,,JUST old habit.....
Coming off Chinook pass at 45/50 east bound, no traffic, and a nice day, ,,,I might go to 6 gear for a mile or two.... NO BAD feeling on the motor but I Don't expect it to do more than compression SMOOTHLY down the grade..(my choice)
I do Preach, Have your RPM band with-in ONE shift if needed..... It's a SAFETY Issue, Using the "throttle" to get OUT of a situation is just as important as being able to use the "breaks"...
Lugging a motor with the Torque a HD has will only tear-out the bottom end.... A lot of riders love to hear it but beware of the soon to follow $$$$ it takes to hear that lovely sound...
I usually can tell by the Feel and the Sound IF I AM LUGGING.... It is like any piston motor, apply power to PULL and by doing so at a LOW rpm, damage can-will be done...
The newer model bikes, FI, shut OFF the gas flow on compression at a set RPM, so when using compression Just For The Purpose of SLOWING under compression NO Backfire...
just my way
This is an interesting thread and I would like to undrestand it better. I think that you are saying that any time I twist the throttle and I do not get a response from the engine and the vibration increases is (lugging). I try to never do this, it is nice to roll through town at a low RPM and I like the idea of one gear down to throttle up.
I have a question about engine braking. When approaching a stop, on my metrics I used to engine brake a lot. Is this recomended on a Harley motor? I typically will shift from 5-3 then EB, then 3-N or 1
