ChopperDoc
There are a lot of numbers on a motorcycle (price, air pressure, wheel base etc.), but only one of them will kill you "TRAIL". There is a reason HD only offers kits to lower their bikes 1" - Anything more and the trail number starts moving toward the red.
In your picture it looks like you are reaching the ground with knees bent and feet flat on the ground, so your lowering plan must be based more on looks than safety.
Lowering to extremes will cause handling problems more dangerious than parts dragging. At some unknown speed you could go into a wobble be it slight or severe.
If you use your glide for riding, I would strongly suggest you leave the ride height alone.
I was riding behind a friend when his bike went into a wobble at 115 mph and the rear wheel was leaving the ground and bouncing from side to side. He managed to get it stopped and after about 45 minutes he was calm enough to ride back home. He is now an expert on trail numbers.
You can read more about it and see diagrams about rake/trail at scootersperformance.com
Just one person's opinion.......
