R_W_B
Senior Member
Let me attempt to sum up this thread.
Ignition fuse is blowing (but not immediately).
The wire that is getting hot is the Red with Black stripe. From the diagrams given by Hoople this wire feeds the 3 fuses, the Lights, Instruments, Ignition and also feeds pin 30 of the starter relay.
With Run/Kill switch OFF, the wire still heats up.
All wiring appears to be OEM.
Unplugged the tip over sensor and the R/B wire still heats up.
Last post the OP says he did do step 1 of Entry #11 in which removing ignition fuse the wire still heats up.
This seems to say there is some confusion still as to the culprit (or culprits).
Freeride77 you say the ignition fuse is blowing, so that denotes a short or cross ciruit with the gray wire circuit.
But you also say the same wire (that feeds the ignition fuse) stops heating up with the Lights fuse is removed. Was the ignition fuse out also ?
If not put the ignition fuse back in, and leave the lights fuse out. Does the wire still heat up ?
