High idle problem
Discussion in 'Engine, Fuel and Exhaust' started by sjcea, Sep 5, 2013.
  1. sjcea
    sjcea Active Member
    104
    This just started the other day on my FLHXI Street Glide 2006 . while riding and then coming to a stop I noticed the idle running high ( about 2100 rpm ) no idea why it did this ? I hitbtje throttle a few times an no change ? It stated to come back to normal after a few minutes . bike sat at work for 9 hours . when I went to go home and started it cold . the idle raced up again over 2000 for about 15 seconds then dropped ? What's causing this ? Bike has just over 20k miles . dirty IAC or perhaps a bad TPS ? Any help would be appreciated!!
  2. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Could be either...disconnect the TPS plug from behind your a/c intake, ensure it's clean, coat pins with dielectric grease and then re-connect.
    Also, when turning off EFI bikes, make sure you let the motor "idle-down" to 1K before shutting off. The TPS will recall last setting and high idle conditions are know to crop-up, when you turn-off @ anything other than normal idle.
  3. HDDon
    5,544
    133
    229
    Clean the Idle Air Control.
  4. Jack Klarich
    If this is not throttle by wire, try lubing your throttle cables, I had 1 cable break last year on the road, it did the same thing you describe here:s
  5. Jack Klarich
  6. sjcea
    sjcea Active Member
    104
    06 model not 09
  7. HDDon
    5,544
    133
    229
  8. Jack Klarich
    My mistake, I was running a split screen at that time, that post still bares reading tho it has good info about a high idle found in the self help section:D
  9. sjcea
    sjcea Active Member
    104
    I cleaned the IAC today and i would say it was pretty dirty . went ahead and cleaned the rest of the air intake as well while I was at it . fired the bike up afterwards and it was idling normal . throttle response seemed a bit more snappier than before . if this doesn't solve it I will replace the TPS as well
  10. Hoople
    Hoople Account Removed
    7,198
    34
    Why? A bad TPS won't increase idle speed by 1000 RPM. You need more air to do that, not more fuel.
