Help please! Fuel priming issue
Discussion in 'Engine, Fuel and Exhaust' started by Streetglider08, Mar 4, 2011.
  1. Streetglider08
    Streetglider08 Member
    89
    So I'm on my way to bike week about 400 miles away from home. I noticed when I got to the hotel that my fuel pump was priming while the bike was still running and it won't stop priming. Must of happened since my last fill up 40 miles ago. I need help bad. I tried turning everything off and back on and it still happens.
  2. Bodeen
    4,647
    73
    222
    I'm no fuel injection expert but it sounds like maybe the fuel line inside the tank has cracks/holes and the pump never reaches pressure to shut off. Assuming you have no visible fuel leaks external to the tank. If it wasnt full of gas you would probably experience a rough running bike because then air would be introduced with the fuel. I'm hopeful you'll get it straightened out and get it back on the road. Let us know how it works out.
    Bodeen
  3. orgredneck
    orgredneck Member
    61
    are you saying you hear the pump louder when engine is running?
    pump runs when you turn key on to prime system.
    with engine running pump is running also,
    if its louder now might be pump going bad.
  4. Streetglider08
    89
    Yea that could be it to. Getting ready to hit the road again. I guess I'll find out
  5. deucedog
    deucedog Active Member
    326
    Try turning the key on, but don't start the bike. You should hear the fuel pump run for 3-4 seconds then stop. If it continues to run, the chances are good that there's a hole in the fuel line inside the tank. You may be able to hear a 'hissing' noise coming from the tank if this is the case.
  6. NEWHD74FAN
    8,191
    98
    19
  7. NEWHD74FAN
    8,191
    98
    19
    Yep, the "Librarian" has it going on...I just read original poster detail and remembered my dislike of plastic being used in EFI high pressure fueling systems and just jumped right in. Still not convinced replacing cracked plastic with more plastic is a solution...but that is just me, and why I still like carburetor simplicity.:hii
  8. Streetglider08
    89
    The hissing stops after 4 seconds.... Until I start the bike and then it comes back. Another thing I noticed today was that my oil pressure was a little higher then norm. Usually it runs right at 32 when cruising but today it was at 45. But only for a short while. Then it went back to normal. Everytime I got gas after that and started my bike up it would do the same thing for the first 5-10 miles and then it would operate normally. Is there a sensor or something that could have this effect on both issues?
  9. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,823
    133
    208
    That should be,
    Signed "The LIBRARIAN"
    :rofl :rofl
  10. deucedog
    326
    I have no idea how a hole in the fuel line would affect oil pressure? I highly doubt a sensor would do it. But, the hissing will stop once the pressure in the line dissipates. When you start the bike, the pump is now pressurizing the line and the hissing will begin.
