ironmark
Junior Member
You should have floating rotors on the bike already @ least my 08 (non-ABS) came with floating rotors & calipers . I had the same problem as you, my bike was surging when the front brakes were applied. I just changed the brake pads and the surging stopped, I didn't even scuff the rotor any. It is real easy to change the brake pads so try that first then if the surging continues then change the rotors you can still use the same brake pads . I am not sure if the HD brake pads are semi-metallic or full metallic (never asked) but it looked like my brake pads were glazed some.
