Fork Oil Poll
Discussion in 'Oil' started by glider., Oct 26, 2007.
Fork Oil Poll
  1. HD SE Oil
    155 vote(s)
    65.1%
  2. Bel Ray
    39 vote(s)
    16.4%
  3. Royal Purple
    4 vote(s)
    1.7%
  4. Other (Please specify)
    40 vote(s)
    16.8%
  1. glider.
    glider. BOT Machine
    18
    Just one more here. What fork oil are you using.
    Feel free to give your comments on it also.
  2. Not Very PC
    Not Very PC R.I.P
    527
    I use nothing but Bel-Ray for 30+ years, Street bikes & Dirt bikes as well.
    Change street bikes every 8-10,000 miles.
  3. sedeuce
    sedeuce Member
    10
    I am interested to find out what you (glider) suggest. I have just changed to mobil 1, formula + , golden spectro and I used the MM. I had formula + in all three holes. Going for a ride today and will give you my report. At 10,000 miles and the book says to change.
  4. glider
    56
    What's the MM?
    I sure hope you didn't have the F+ in the engine.
    I like the M1 V Twin in the engine
    F+ in the primary and spectro platinum in the trans. (6 speed)
  5. sedeuce
    sedeuce Member
    10
    se oil in motor and MM is marvel mystery oil
  6. glider
    56
    WOW! I never thought of that (MM):D
    Best you are using a full synthetic now (M1) instead of the syn 3
  7. ffmedic32
    ffmedic32 Member
    17
    Glider ? for ya........Why does the MOCO say for off road use only on the SE Racing Fork Oil.........Is it just another of their liability things.....I picked some up the other day to try,,have not changed it yet tho to see...
  8. glider
    56
    The heavy duty SE oil (20wt) is for off road use, the standard SE oil is 15 wt and can be used on the streets without a problem.
  9. USMCCWO5
    USMCCWO5 Junior Member
    419
    Had my indy changing my fork oil in the past, long story short, I am doing my own maintenance. They were using 20 wt in my 2007 FHLRC. Is that ok to continue to use?
    I have no complaints about the performance that the 20 wt is giving me, so I don't want to mess up a good thing.
    Do I need the Kent-Moore tool described in the service manual or is there a common method that can be used without the additional tool to extract the oil to an even amount in both tubes? Thanks in advance.
  10. glider
    56
    Depending on brand, the 20 wt is a bit stiff., fork oils aren't graded the same as the engine or trans oil from manufacturer to manufacturer. Normally 15 wt is as heavy as you want to go on the street. I ran 15 in my RK and the front end was noticeably stiffer than the 5 wt that comes stock.
    As far as servicing the front end, here's how I do it.
    Easy Fork Oil Change On Baggers - Harley Davidson Community
