footpegs wont stay up
Discussion in 'Softail Models' started by Jdsmitty10, Mar 23, 2010.
  1. Jdsmitty10
    Jdsmitty10 Active Member
    244
    My rear footpegs won't stay up when riding solo. its annoying.. I put brand new D washers in there when i replaced my stock pegs last summer. Ever since, after I ride a couple miles, they are vibrated down about half way.. Any suggestions?
    Thanks!
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Do you have the concave side of the spring washer facing the stationary yoke?
  3. glider
    50
    I find if you just tighten the bolts a bit more with good washers they will stay up.
  4. Jdsmitty10
    244
    I cant remember, i will have to take a look.
    Mine doesn't have bolts to tighten. There are just pins to go through with the clips that hold them on..can't think of the name of those clips..
  5. Hoople
    7,198
    34
    Possibly "E" clips?
  6. Jdsmitty10
    244
    basically shaped like a c with little holes on each side.. had to buy the tool to take them on and off..just cant remember what the tool is called.. u have to spread the clip out over the pin to get it off...
  7. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    I think you mean snap-ring pliers. My Heritage has them also and 1 side always drops down. Think I'll put a shim washer in with the concave washer.
  8. Jack Klarich
    They are like a wave washer, try new ones
  9. Chopper
    Chopper Senior Member
    1,632
    19
    You should be able to take the pins out and install mounting bolts so you can tighten them up like Glider suggested, or for a lot of the custom pegs you can use a wave washer on each side if there's room.
  10. Carpfish
    Carpfish Member
    35
    Yarn works...kidding! I would take the tension washer out and bend it a bit more to make more tension. You could use vice to help. You may save a few bucks.
    [​IMG]
