Exhaust
Discussion in 'Engine, Fuel and Exhaust' started by Drumrguy, Oct 29, 2009.
  1. Drumrguy
    Drumrguy Account Removed
    573
    Got a ??????????????. Can I change my Rush slip-on mufflers for another set of slip-on mufflers without have to put the bike back on the dyno?????? I just got it back and no I think I want a different look to my mufflers? I am such a pain, my wife says I am worse than a woman with this bike, I cannot make up my mind.
    Shouldn't be a major change going to another set of slipons. IF you loose anything it probably wouldn't be enough to notice. If you went from slipons to drags, different story.
  3. Drumrguy
    573
    That is what I thought, just wanted to double check. Thanks! :cheers
  4. glens
    glens Banned
    96
    What size baffles you got in the Rushes and what're you contemplating?
  5. Drumrguy
    573
    To be honest, I do not know. They were on the bike when I bought it, why you ask, have something in mind.
  6. FLHXTom29715
    FLHXTom29715 Active Member
    162
    You could go with another set of rush slip ons, the ones that you can change the tip's on, you can get down turn, tapered, etc. tips and keep the same size baffles in them. If you wan to go with a different brand, I loved my V&H turndown on my 98 RKC, the don't have them yet for my 09 SG, so I went with a set of rush with 2" baffle slip ons, they are louder than my V&H, but worked for me. If looks is all you really want to change, and you like the sound, performance and finish of rush, get the ones with the tips. And a deer whistle :s
  7. Drumrguy
    573
    I actually have the ones you can change the tips on, what is up with the different size baffles they have, I do not understand that. What is the purpose?
  8. FLHXTom29715
    162
    Baffles give you back pressure on the exhaust and torque. The smaller the baffle 1.75" the more back pressure you have the more torque you produce on the bottom end and they are the most quiet of the pipes, still louder than stock. 2.5" baffles largest rush makes, least amount of pressure and loudest, and a little more loss on low end torque. You want to keep the amount of air flow in and out close to equal as possible for the best performance.
  9. Drumrguy
    573
    So which ones would you run? I have 155o kit on my bike, cams, cnc ported heads, etc.
  10. glider
    1 1/2" on the left and 1 3/4' on the right.
