One thing I did leave out on my first post is that I did install the SE Big Twin compensator Part#40274-08.  The stock compensator will not hold up well when you start increasing the tourque and HP.  I had to do this after the stage II upgrade.  Also I just purchased an SE pro super tuner.  I am going to use it to see if I cant change the the map to decrease the engine heat a little by fooling with the air fuel mix.
