Crank but will not start?
Discussion in 'Electrical' started by Moralem2006, Aug 5, 2010.
  1. Moralem2006
    Moralem2006 New Member
    4
    Here is my problem guys. I have 2001 duece that had the run light left on for about a month. I was out on business trip, anyways I have already charged the battery its reading 12.88 volts. When I go to to start I dont hear the efi pump prime? The bike will crank but no start ..please help?:cheers
  2. HDDon
    5,542
    133
    229
    Was that 12.88 with the charger on?
  3. Moralem2006
    4
    No sir! And I also all the fuses...but still nothing???
  4. whatyardwork
    whatyardwork Banned
    829
    4
    Fuel injected?
  5. Moralem2006
    4
    Changed all the fuses...
    Yes its fuel injected.. I dont hear it priming so where do I start looking first?
  6. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    make sure the kill switch is on and not corroded
  7. whatyardwork
    whatyardwork Banned
    829
    4
    Have you done any rescent mods to it?
  8. Moralem2006
    4
    No mods?
  9. TwoTallWyo
    TwoTallWyo Member
    39
    got spark?
  10. Safehaven
    Safehaven Active Member
    351
    if you have spark and compression is good, you can verify that it`s the injectors failing by adding a tiny drop of starter fluid in the cylinders through the spark plug hole, then insert spark plugs and crank the engine, it should fire and then stall..
    if so it will be your fuel delivery which is not working. Since you don`t hear your fuel pump pressuring up, checking the electrics to this component would be where I`d start.
