Bummed out....dead battery...beautiful day
Discussion in 'General Harley Davidson Topic' started by ROOT BEER KING, Mar 7, 2010.
  1. RUSHMORE_14
    RUSHMORE_14 Junior Member
    538
    When I went to take my bike out of the garage after being on a charger for a month and a half.....the battery was totally dead. I wanted to take it out for a spin......but the freight train that was my emotion was derailed, going to get a battery tomorrow and a new tender. Any suggestions?:(
  2. TQuentin1
    4,737
    142
    Hope although you said "charger", you meant "tender". I have a Battery Tender Jr. that I have seen on sale on the internet for around $20. This is a good little unit. I keep my tender connected when I park it in the garage every day.
    Whatever new battery you choose, I suggest a tender from the get-go.
  3. RUSHMORE_14
    538
    Yes, tender is what I meant.....still gonna buy battery though
  4. dfbales
    dfbales Active Member
    143
    from the age of your bike (almost new) and having it on a tender all winter I assume in a garage or shed, you battery should be OK, before this happens again you might want to check the outlet with the lights turned off. I once bought a new freezer filled it lost the food, got a free replacement freezer and lost it again, found out the outlet was tied to the light switch. talk about a red face, both my partner and myself were journeyman electric ans.:newsmile011:
  5. NEWHD74FAN
    8,191
    98
    19
    Wow, a battery failure in one year...and with use of a battery tender. Sorry you experienced this failure 09 Heritage, did the charger show that it was charging and the in line fuse is intact? Check to be sure!
    The other thing is, knowing how EVERYTHING relies on it, you would also think that local isolated battery backup and "Energy Star" low level power consumption designs would be put higher up on MOCO priority list so the battery would not have such a high "loss mode" when parked with alarm enabled for more than a month w/o charge.
  6. HarryB737
    HarryB737 Junior Member
    656
    Here's my experience... I had a float charger fail internally & the result was it started putting out 19 volts. Needless to say it COOKED my battery. The float charger I WAS using was not a Battery Tender... but it is now !! So in addition to checking your battery, also check the output of your charger...
  7. Jammr
    Jammr Active Member
    195
  8. glider
    Are you sure it isn't a bad connection on the battery being only a year old?
  9. silentflyer
    silentflyer Active Member
    341
    Yes check the terminals, check it with a "load' type meter after a re-charge, not sure but it may be under warrenty with your dealer?
  10. HD4ME!
    HD4ME! Active Member
    281
    I had the same thing happen to me not too long ago. Wound up being a bad battery which the dealership replaced under warranty.
