Bike Lift
Discussion in 'Softail Models' started by BOWHIKER, May 10, 2010.
  1. BOWHIKER
    BOWHIKER Junior Member
    434
    5
    I'm considering getting a bike lift for my soft tail , sure would be easier to do service and cleaning with one . I was wondering that when you roll the jack under the bike do I need the stand it up straight before jacking it up ? It looks to me as if it would level out on it's own as the jack started going up but having never used one before wasn't sure . I'd hate like you know what to tip it over , my wife would never let me hear the end of it if I did that . then after it's up is when you strap it so it won't fall correct .
  2. R. Lewis
    2,183
    5
    Do you have any particular lift in mind ?
  3. BOWHIKER
    434
    5
    not for sure yet maybe sears or the red one can't remember the brand .
  4. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    BOWHIKER; you're going to get quite a few posts on this & might want to look at glider's thread on jacks/lifts. I'm going to recommend the J&S jack (J&S Jacks - Motorcycle Lift, Motorcycle Jack, Wheel Chock, Oil Pan Adapter - USA Made, Wisconsin) b/c it's one of the highly touted on any forum (along w/PitBull). Main reason to look into one of these "spendier" jacks is the design...low to the ground (fits under w/o blocking), stable (good quality metal) and controlled raise/lowering (no need to hold bike).
    Believe me...you won't be disappointed w/the J&S - make it a gift to yourself (and your bike)...;)
  5. fin_676
    5,789
    153
    288
    I always hold the bike upright and keep checking that the jack is in a good place as it goes up justn to ensure the frame is properly supported
  6. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I must stand all of my bikes straight up to get the lift under the far side of the frame. Even if I didn't, I would still hold it upright just to make sure it was level. As often as I use my jack, I only go until it's just supported, then go and look at the far side to make sure the lift rails are far enough through.
  7. RetiredJake
    RetiredJake Junior Member
    862
    I've had the PitBull lift for 2 years and can't say enough good things about it. I got the Dyna model, so it works on both the Dyna and Ultra. This thing works like a champ, does not require you to tie down the bike, and lifts to 26". It makes working and cleaning the bike much easier.
  8. flhrrider
    flhrrider Member
    74
    +1 I really like my J&S.
  9. Jonas
    Jonas Junior Member
    408
    I have the craftsman red jack. I hold my 04 RoadKing straight when I slide the jack under. I have to put the shovelhead rear tire on a 2X6, so the jack will slide under it.
    I will never recommend the RED Sears jack to anyone again. There are tons of dissapointed people with it(my brother whom I suggested it to is one). Seems a large percentage of the bottlejacks go bad and sears has no fix.
    It's cheap because it's cheap.
  10. Trek
    Trek Junior Member
    575
    J&S Jack. I have one and love it. It will lift the bike while it is on the jiffy stand and put it right back down on it also. Check out there web site and look at the video clip.
