free website stats program Bike just shuts down at 90mph | Harley Davidson Forums
spartacus55
Was motoring up the hi-way pushing it up to about 95 mph when all of a sudden the engine cutout Ithought i had run out of gas but my idiot light did'nt come on yet i was in the fast lane with traffic coming up rapidly behind me and i found myself having to cross about five lanes of traffic to get to the shoulder not exactly fun during rush over traffic and not one cager gave me a brake i made it over three lanes when i downshifted and boom the engine started back up. I just had new bars and all the cables replaced anyone have a similar proiblem
Long shot but maybe air in the fuel line?
No other things you've noticed? I'm sure there are tons of things you can check, but I've only had that happening when driving a car, I didn't bleed the fuel line correctly and the first time I gave it the beans, the trapped air went into the injectors and misfired / stalled. Off course I pulled the clutch, but like yourself, as soon as I let go of it on the shoulder while still in motion it came back to life..
sure glad you made it out unharmed.
Take care,
Thanks for the help safe after the restart it ran perfect iguess it could be an air bubble but i'm still concerned it could be something else like a rev limiter malfunction well i'm having cruise installed next week maybe they can find something then thanx again
Not sure if this will help but bring it back up to the speed again and see if it shuts down again. It may be a max speed sensor built in to the system, shuts it down at a certain speed. Had a truck that would do that. It is just like the cruise control on my bike cannot set it over 85 mph. If the bike is completely stock that could be the problem, "THE MANS" way of keeping control of the people (LOL).
This is all just food for thought.
Often the last thing worked on is the culprit for a problem. I'd carefully check all the wiring (esp. on/off switch) on those new bars. There were a LOT of wires/connections involved in that change. One marginal connection would do it.
Maybe you have an automatic ticket saver mode. Kidding of course. But it might be circuit breaker that heated a bit to open the circuit than reset when it cooled. Just a uneducated guess.
This is just my 2cents, but the most recent change(handlebars) is where I'd look. Could be the kill switch shorting out or maybe a wire is broke and moves. I'd open up the awitch housings and look at the kill switch and wires. Doesn't take much to break the solder joint on the kill switch.
Could be as Smitty says, you are hitting the rev limiter in lower gear. It could also be fuel starvation, air in the fuel line (the dreaded tiny holes in the fuel lines), clogged inlet filter (water or debris from last fill up), overheating (real that the rear cylinder is cutting out) or false (bad temperature sensor), or some electronic failure (is there a key symbol illuminated indicating diagnostic codes were thrown)? Plenty of possiblities and finally is the bike under warranty that you should at least alert the dealer that you had the problem to see if there are service bulletins pending?
